3020T- DJ CNC Users thread
Ahhh. Yes, I have been looking at Banggood, to try and work out which you have.. (and you do use the terminology "drills" which is a little confusing)
You need to go for flat (square) bottom one or two flute endmills. The only ones I see there that might be suitable are "3.175mm Carbide CNC 2 Flute Spiralbohrer Schaftfräser Router 8mm" or if you must go small.. "1.0mm 4mm CEL 2 Flute Carbide Flachkopffräser Fräser"
The rotary rasps or rotary burrs are not suitable (they are more for composite materials like PCB's)
I currently have some cheap 2 flute endmills on order from Ebay to try out... but until I do I can not really comment on the price differences.
T
