I have this old Tesla EKL 021 compressor, it comes from an old console, it seems to be a FET compressor (Germanium compressor I read on a forum) But I can't find much information.
I found the schematics.
On the schematics, the voltage is -24VDC on pin a12 and b12, the input is on pin a4 and ground is on b4, b6, b8, b1.
The output seems to be a6 but I'm not sure because the is a signal but It's bigger than the input ...
I also don't know what is a8 (side chain ?) and a10.
The settings on the front are a little bit strange, the first know is "KOMPR." it's a switch with 4 positions (lim, 6, 12, 18), I thought it was a ratio but the way I plugged it (output on a6) it just seems to act as a gain.
Next setting is "EXP." it's a pot, it goes from 45dB to 65dB, I don't know what it is for ???
The last setting is "T SEC.", it seems to be a time constant or just the release time of the compressor, it's a switch with 5 positions.
There are also 5 trim pots inside but I don't know what they do.
Does anyone know this compressor or could help me read the schematics ?
Thanks a lot.
Link to the Schematics
Thanks a lot.
