mackie 1604 vlz pro main out problem
melac
Active member
Linz / Austria
my mackie just quitted his job - the left channel is missing. control room and subgroups are working fine - i even get both sides from the main inserts. the inserts itself are working...
any suggestions?
thanks and greetings
christoph
Does it work if you connect for example a compressor in the insert and put it on bypass?
Most problems I had with (cheap) mixers was with inserts nog passing audio to the channels when nothing was inserted due to broken connectors.
I have had several units in for service with this kind of problem. Problems I remember is:
Bad flat cables
Bad insert jacks
And finaly the "pain in the AS to find fault"! bad "through plates"( hope that's the right english word), the connection between the sides of the circuitboard.
Also check the master fader!!
