Being an electronic engineer all my life i have built a lot of tube amplifiers.
In the 60's when i was 14 years old i built my first amplifier. The concept was based on an article i found in Radio Bulletin-Elektronics. The article was called "The last of the Mohicans".
The amplifier had an EF86 as a pre-amplifier, an ECF82 as a phase-shifter and 2 EL84 as a pentode in the output. The schematic was a close clone to the wellknown Radford STA15 amplifier. Later the concept was changed to have a STA25 amplifier with 2 EL34 tubes to raise the output.
I used this amplifier until the mid 80's and then rebuild the amplifier with 2 KT88 for a 100 watt of output. I've never heard a better sounding amplifier. This was because of the use of that ECF82 as a phase shifter which is not often found as a phase-shifter. I will lookup the schematics from my collection and make them available to you.
Close to the village where i lived then (and live now) there was a city where a guy lived by the name of Menno van der Veen. Menno is a real tube amplifier guru and he founded his own company called "The Tube Society" Menno gives many lectures and presentations at several AES conventions all over the world. Also he has written many books on the subject of tube amplifiers. I can safely say that my Tube-Bible is the book Modern High-End Valve Amplifiers based on toroidal output transformers
(ISBN 0-905705-63-7) written by Menno.
On his website you find a description of a project he wrote and that is very helpfull in understanding the concepts of tube amplifiers.
It's a universal amplifier concept where you can build some 20 different amplifiers and sort out what is convienient to you.
The designs range from 5-80 Watts output with selectable primary and secondary impedances, which include Single Ended and Push-Pull with Triode and Pentode configurations .
All the components are very easy to obtain. This includes the Power and Output Transformers.
For the tubes you have a collection to chose from :
EL34/KT66/KT88/6550/EL156/6CA7/6L6
Only the input driver is Always the same : ECC81/12AT7
You'll find the schematics, explanation and construction here :
http://www.mennovanderveen.nl/eng/index.html
In the menu on the left hand you choose "The Project"
