Illuminater
Member
- Joined
- Jan 30, 2016
- Messages
- 9
Hi!
I'm planning to build a ribbon microphone and I have some questions. It seems as if this is the place to be for microphone questions.
Prior to this I've built and tinkered a lot with guitar amplifiers. Well, building guitar amps is not a HiFi thing, quite the opposite actually, MOJO. Now I want to build a microphone, that sound fairly good.
The plan, at the moment, is to build a ribbon motor and hook it up to a common source stage, or on stage for each line. The stages will be powered by 48V phantom. First issue I have is the impedance of the ribbon. It seems impossible to do this without a transformer between the motor and the gain stages. If I go with a transformer on the input, how do I choose transformer? I have seen some Ribbon Microphone Transformers vend on the net, but they all seem to be matched for passive ribbon microphones. Threading on my school knowledge I have a hunch that these 'passive transformers' will cut the cheese, but is there better transformers for active ribbon microphones, or lets put it, is there a more intelligent way of choosing transformer for an active ribbon mic? Second question I have is about the common source stage. Are there some dos and don'ts I should be aware of. The plan is to buff the signal 25 to 30 dB, seems plausible given the phantom power of standard recording equipment. The first iteration of the gain stages will be more or less without filtering, possible a Miller capacitor to cut high frequencies.
Summary
Tranformer: How do I choose a transformer, where do I find them?
Gain stages: Dos and don'ts.
Please comment, I'll post gain stage schematics and a microphone layout in a day or two.
Cheers!
Summary
Cheers!
