Stereo Linking 1176 Clones
idylldon
Idyllwild, CA
I've just finished up a dual 1176 unit in one box and was wondering if anyone has successfully used them linked. If so, how did you go about it? I've read the threads I could find, but never found any follow-up to the posts that mentioned trying to link them.
Don
Works great. The best thing to do is make sure your FET's are all reasonably well matched, then tie point 7 from both units together via a SPST switch.
Dean
yup, it's simple as that. If your FET's are not tracking well, build a small box like the 1176SA stereo adapter (yes, there is a schematic somewhere around)
Jakob E.
Thanks, guys. I used closely matched FETs on both boards, so it should work out fine once I hook up the 7s.
If not, I do have that schematic around somewhere for the UREI linking box.
Don
