FS - 2X JE-990 DOA - Altec 470A
Whoops
GDIY Supporter
Portugal
I'm selling some stuff I bought over the years but will not have any time soon to use.
Will keep updating this thread with new items.
2X JE-990 DOA - Discreet Opamps - Tested/Perfectly Working
Very Popular and High Performance Opamp originally designed by Dean Jensen,
used and manufactured also by The John Hardy Company, althoug the JH 990 used SMD components nowadays, that it's not the case with these JE-990.
60€ or 67.6 dollars for the Pair + shipping
1x NOS Altec 470A
Don't have much info about this, I've paid 50 euros + shipping for it.
It's NOS , still in the original box.
2 transformers inside
Do me an offer
SOLD
2x Altec BC315 channel strip modules plus connectors boards
these are working modules from an Amek BCIII console that was parted out.
Mic Pre and Eq sections designed by Mr Rupert Neve
Same Mic Pre as in the popular  Amek 9098
The Pots in the channel strips are conductive plastic and the fader is Penny and Giles
I will provide schematics and pinout layout
Will make a great rackup job
200euros or 224 dollars each + shipping
SOLD
2x Green Preamps V14 - all mic pre components stuffed [/b]
These are 2 working preamps, have all the components for the Mic preamp circuit, stepped rotary gain switch with resistors soldered, output pot, switches for 48V , phase and  HP filter.
The only part of the pcb that is not stuffed is the section for the LED metering that I was not going to use, it's up to you if you want the metering or not,  although the Green Pre doesn't need it in order to work.
It's a classic DIY project, a very clean and powerful mic preamp. You just need a PSU and you have 2 amazing preamps for cheap.
Will provide the documents for this project
60 euros or 67 dollars each + shipping
SOLD
4X Altec 1588B Mic transistor preamp bottles with input transformer
all 4 tested fine
33.5 dbs of gain
30€ each + shipping
25€ each if you buy all 4 of them
SOLD
20x  UREI CTS 20K Slider Fader P/N 15-0295 for 5xx range EQ's
The faders are used but work properly
Length end to end is 65mm, width is 8mm, height from bottom of body to top of sliver lever is 38mm.
The black knobs for these sliders are P/N 24-0055.
they cost 20 dollars in this website:
http://www.studioelectronics.biz/sunshop/index.php?l=product_detail&p=1680
I will sell the 20 faders for 15euros
items are located in Portugal
I will ship worldwide
will post pictures soon
Hi Whoops,
Interested in the greens but where are you located, for the shipping cost :)
Kind Regards..
