Neumann CMV5 output transformer ratio and VF14 schematic version as curio
ln76d
Gallifrey
Still didn't found answer - what's transformer ratio for standard EF12 version.
Anyone knows?
http://www.elektroakustika.cz/images/cmv/cmv5/cmv5ef12.jpg
Funny thing happened on the way to the ratio find!
I found schematic for CMV5 with , I don't know is it commonly known but always worth to paste here ;)
http://www.elektroakustika.cz/images/cmv/cmv5/cmv5vf14.jpg
There's a lot of other great materials on elektroakustika.cz!
The transformer GN107 has 6,7:1 ratio. This transformer is manufactured today only by Haufe  on special order, for Andreas Grosser, who is engaged in repair of old microphones. The transformer is a copy of the technical characteristics of old GN107.
Thanks o3misha!
I was suspecting 6-7:1 ratio, but do you know is this the same or similar to the EF12 version?
I didn't found schematic with EF12 which have transformer model written.
I know only the one GN107. I have no idea about EF12 version's transformer, but if it is GN107, then it is the same. I know also, that there is U47 version with EF12 tube. bV08 is close to GN107 ( almost the same ratio) but with a bit more clarity in high end and a bit less low end.
ln76d said:
Is there any existing schematic (original of course) of U47/EF12?
I believe the highly esteemed Wagner U47 uses the EF12.
Googling will give you quite a few schematics, but most are "inspired by" and such.
And the "real thing" was, in any case at some point, hidden under a veil of secrecy.
Some whispered only guys like Grosser and Wagner had it.
:-X
Anyway, I may have something for you, Piotr.  ;)
Yeah, i know Wagner version also tried with EF12 build 47 circuit but i would be happy if the original schematic will be existing and someone could share it :)
Question mark here, too.  ::)
Anyway, Andreas Grosser has lots of success with his VF14, drop in, alternatives.
And I believe Gunther Wagner more or less stopped making U47 clones altogether for lack of original parts (other than the tube).
Flea still uses the EF12, though.
I send it again.
No not really enthusiast  ;D
Sit on the balcony, drinking coffe absorb the sun :D
