Wanted: AKG SA 18/3 B stand adapter for AKG C414 (Preferably alive...)
RuudNL
Haule / The Netherlands
Hi, I am looking for an AKG SA 18/3 B stand adapter.
It seems they are no longer produced and have been replaced by a shockmount for the C414.
In some cases the shockmount is too bulky, or is simply not needed.
I have the impression that the stand adapter for the AKG D224 would also fit the C414.
Any ideas or suggestions for an alternative clamp?
There's many option but most important is - does it need to be original AKG adapter?
Also - does it have to be longer as AKG SA 18/3 B and with double regulation?
No, it doesn't need to be an original AKG adapter.
The problem is that is should not be 'longer' than 39 mm.
Diameter should fit a 22 mm microphone.
Audix dclip will fit nicely, am using it sometimes for C414 and usual for MD409 etc.
http://www.audixusa.com/docs_12/units/DCLIP.shtml
It can be also found under different brands and cheaper (If i remember correctly also proel).
