RuudNL
Sometimes condenser microphone capsules fail, because they get polluted and show a certain resistance between the diaphragm and the backplate. This leak resistance is very high, in the order of giga-ohms (I assume).
What I would like to do, is make a measuring device that is able to measure the resistance of a microphone capsule.
This is what I have in mind: use a FET OpAmp, for example a good-old TL071 as a voltage follwer. (Output connected to inverting input). The non inverting input to ground via a 1 Giga-ohm resistor. The output can go (through a resistor) to a measuring instrument. The 'resistor under test' would be connected between the + of the power supply (symmetrical power) and the non-inverting input of the OpAmp. In this case calibration could be like this: full scale = 1 G.Ohm, half scale = 2 G.ohm, 1/10 of the scale = 10 G.ohm. Would this work to measure the leak resistance in a capsule?
(During a quick test I have measured the 'resistance' of several screwdrivers ;D , and some are better than others!)
