That's not a good layout either, I wouldn't trust it. There are better preamp designs around here, even ready to etch files.
I encourage you to learn more, but you shouldn't expect a top performance preamp as your first project and add over that time and money restrictions. You can build a decent mic preamp but you need more research to do so, and it's quite a tricky project to start with.
If you only need them for a make up for a mixer I'd said don't go there, build a summing amp, you said you have a few 5532 which would do for this. You could probably get away with a prototyping PCB for this, the opamp, a bunch of 10k resistors going to the inverting input, one as feedback with a 22pF in parallel for stability, 1k resistor from ground to the non inverting input, decoupling caps and you are good to go. Be tidy with the grounds, use one going straight to the 1k resistor from all the inputs, from there to the output and from there to the bypass caps. Take the PS gnd from the same place as the output. Use 100µF36V caps for decoupling.
2x5532, 40 resistors, 4x47µ caps and 4x22pF caps. Maybe add a few screw terminals to it so it's easier to connect everything. You still need a PS, if you don't have one a 15+15V 500mA transformer, a fuse , two diode bridges, 2x2200µF 50V, one 7815 and one 7915 is all you'll need. If you don't feel confortable dealing with mains ask for help, it can get dangerous pretty quickly... You need to add all the wiring and connectors for this and a case, that's probably more expensive than the unit it self.
Please, don't take it wrong, but don't flush the forum with topics asking people to do your job, one topic explaining what you want to do and what are your resources would get help, 3 topics asking people do your job for a hand full of OA won't.
JS
