U67 calibration input help
ghiatorino
Hello,
Anybody can help me figuring out how to perform some test to my Neumann U67 using the calibration input, in order to check proper frequency response of the amplifier? I suddenly have very low (no bass) distorted output on all patterns.
PSU is not original but custom built to specs, worked fine for years till yesterday.
How can i inject the 600 ohm test signal? i mean, since the mic needs to be connected (in order to test amplifier response) i need to inject signal from pin 6 on the tuchel inside the PSU?
Should i keep the head assembly connected?
I would also perform some voltages test on PSU, can you suggest me a proper dummy load and where it should be connected?
Thanks everybody,
cheers
t
