Hairball 1176 rack REV A Question / possible problem.
ccommon
Member
Hey guys ,
I picked up a Hairball rev a rack kit used, and it show up great , no problem there.  I did the build , no problems there .
The unit powered up great , voltages are spot on , and It Cal'd with no problem .
The unit sounds great ! no real noise , and seemingly no issues at all .
The one think I Notice  is that its got a Lot! of gain . I know the Rev A's are 5-6 DB " hotter "  so i just wanted to conirm that its acting normal .
I have it on a  guitar at the moment , and the Input at a little bit over "48" , and the output at in between 24 and 18, Im getting a reduction of about -3 to almost -7Db.  at 4:1
does that at all sound about right ?
let me know your thoughts
thanks
-Chris
ccommon said:
Hey guys ,
thanks
-Chris
Please use the official support thread.
No way of knowing if it's correct without knowing the input level coming in. The 4:1 has the lowest threshold. Doesn't seem off if the level is on the hot side.
Mike
Mike
sorry , next time I will use the correct thread...
its on a guitar , out of protools ( -6.5 db ) on the PT " VU"
not sure if that helps..
can I move this thread to the correct one ?
Just post any follow up to the correct thread.
I think you unit is fine though. You can double check your calibration if anything.
