peterc
Some pics of my latest incarnation of the good ol' Green....
Knobs from RS, front panel is Fotocal/Lasertran.
Also I noticed you don't run a ground to the Pre's from the PSU, any reason?
How many volts is that big blue 47uf?
And is it just me, or are your voltage regs on your psu aimed opposite the way they are shown on the parts layout?
Is there a reason for it being 100v? Mine is 63v
about the grounding...if you attach all the xlrs together and to the mains in ground, you don't have to use the preamps input ground wire, or shouldn't?
My question is, do you ALSO put in the silkscreened link, or ignore it? (only use it for post-trim meter?)
