chriss
Hello,
I am currently doing a bit of 'research' on the LA2A and the T4B. Since I know I'm not alone in this I try to discuss some things here:
1.)
There seem to be different versions of T4A / T4B:
The Audio-Cyclopedia-circuit shows only one LDR between pin 7 and 8 the circuit of the LA3A and LA2A show two LDR's in parallel here.
Pins 5 and 6 are the same in all circuits. Since this is used for metering only it seems to be of less interest anyway.
Between pins 2 and 3 there is the EL-foil in all the circuits but in the T4A there is a resistor between 3 and 4. In the T4B there seems to be another LDR in parallel to the EL-foil.
Since I have never seen this LDR in any of the projects here on the forum I wonder what do you guys think about that?
And the three circuits show there should be T4's with 2, with 3 and with 4 LDR's?!... All the clones I have seen here only use 2 LDR's.
Any opinions about this?
2.)
Does anyone know a source for the LDR's in Germany or otherwhere in Europe?
3.)
The LA2A uses 12AX7 and 12BH7 for the gain-make-up-stage. The 12AX7 could be replaced with ECC83 but what about the 12BH7, is there a more common tube or a tube more spread in Europe that it could be replaced with? ECC88, ECC808, maybe?
What is the function of the 12BH7 anyway? Is this a phase-invertor? Would that make sense in this circiut? I don't know very much about tube-technology but I think I understood that the phase-invertor is needed to create a symmetrical signal for the power-amp tubes. But for driving an autput transformer is this necessary? Maybe it's not a phase-invertor, I'm sure you can tell me!
Or maybe there is a complete replacement-circuit for this amp? How much dB does it make up anyway? 34? So I could just take a V72. (just kidding...)
4.)
Can anyone tell the max. AC at the EL-foil that LA3 or LA2 put out? Just to have a ballpark to where I have to get the amplification...
5.)
Is there any idea what the transformer for EL-foil in the LA3A could be replaced with? I have done some tests with different ones connected to my Freq.generator. The only one that made the EL shine was an reverse-connected power-transformer that only worked around 400Hz. I have tried a 1:10 Audio-transformer that didn't work. Maybe the output of the generator is not high enough. I will try two of the 1:10's in parallel today and maybe another F/G.
Does anyone know the amplification that the discrete amp in the LA3A puts out?
So this is it for the beginning. I hope interesting feedback to come ahead...
thanks
Chris
1.)
2.)
3.)
4.)
5.)
thanks
Chris
