Polytone Minibrute II LM391 and bias issues.
mkiijam
I am working on a Polytone Minibrute II that had a ton of crossover distortion. I am able to scope the output of the driver IC and reduce the crossover distortion to minimum, but I am concerned this might end up in thermal runaway at some future point from what I have heard about this amps.
According to the schematics I have found the driver IC should be a LM391N-80 but there is a LM391N-100 installed. I have read that this discrepancy might cause problems?
I have also read that these amps are supposed to be run so "cold" that they will have crossover distortion. Any thoughts on all of this?
I used a lm391(?)  in a modest power stage for a consumer product (hifi audio delay) I designed for Bozak decades ago.
I had to attach an output stage bias transistor to the same heatsink as the power devices to improve thermal tracking.
This was decades ago so I don't recall all the minor details but yes, the cookbook application design is not as hifi, or thermally stable  as you would hope.
Same thing, higher voltage spec.
There is some reason the '391 chip never got popular.
Putting the on-chip bias a mile away (OK, 2 inches) from the drivers it must track was ignorant.
This seems to be a version *with* added tracking diodes.
http://el34world.com/charts/Schematics/files/polytone/Polytone%20378%20Power%20Amp%20Schematic.pdf
I would not sweat mild crossover in a stage-amp.
