Noise Contribution Of Emitter Resistors
Samuel Groner
Zürich, Switzerland
Hi
I recently read an article by Baxandall (published in Gayfords "Microphone Engineering Handbook") describing theoretical prediction of transistor noise. He concludes with the following equations for the equivalent noise resistances:
RNv = rbb + 1/(2*gm)
RNi = (2*hfe)/gm
where
gm = (q*Ic)/(k*T)
q = 1.6xe-19 C
k = Boltzmann
How do I include emitter resistors in this equations? Do they show up as series resistors of the base source impedance? This would mean I just add them to the equivalent noise resistances, right?
Thanks for your answers!
Samuel
For RNv it's a resistor added to the other two terms.
For RNi---I usually just model the input noise as a current generator at the base, using the shot noise formula for i sub n squared of 2*q*Ib, rather than supposing that is is a resistor. And then also usually apply a fudge factor upwards a bit---bipolars tend to show their excess/low freq current noise earlier than for voltage noise as you go down in frequency.
I'm too lazy to reconcile Peter B.'s expression right now but I'll bet they agree ;-)
Where's my post??
I replied to this a couple of hours ago! I guess my post got lost in digi-hell. Anyway, hope I can help you some other time.
/stu
