Need four small countersunk holes drilled in Los Angeles
soapfoot
LA + Brooklyn
Hello! Need a total of four small countersunk holes drilled in a precise location in the steel side rails of some FLEA C12 microphone bodies (one hole per rail).
Hole diameter about 1.5mm; anything reasonably close to that should be okay.
Would prefer someone close enough to drive from Pasadena.
Price negotiable--whatever seems fair.
Hey I am over in Monrovia I have a CNC and should be able to do this for you.
Ah, thanks so much! I forgot to update the post, but I found a machine shop locally who took care of it for me (and did a good job!)
Good to know you’re local, though—maybe I’ll be able to throw some work your way in the future
S&K general precision machining in Glendale
It wasn’t the cheapest, but it was a tricky job and they turned it around quickly
I didn’t get the sense that they worked on this kind of thing often, but they built a fixture just for the job and were very careful not to damage the microphone body
