too much light on heathers when turn on
12afael
Helsinki
I´m finishing a guitar preamp. I use the G9 style power supply for the heathers. (12vAC, bridge, 1000uF, 7812 , 47uF)
the preamp have 2 12ax7.
when I turn on the preamp the heathers glow too much, then go to normal . I fear to burn the tube.
I don´t have a oscilloscope to see if is the voltage the problem, a overshoot I think .
ideas are welcome
12afael
It's common for some tubes to flash bright when they first turn on. EI's and Mullards do that. If it glows bright for more than a second you probably have a problem.
Check that the voltage is actually 12V. If it is, then there's no problem.
Best regards,
Mikkel C. Simonsen
I will try with diferent tubes to check .
my 1987 plexi amp don´t glow on that way. so I think it could be a problem .
thanx
12afael
I just noticed that you said you hooked the heaters up to 12VAC, I'm pretty sure that 12AX7's are supposed to be hooked up either to 12VDC or 6VAC.
[quote author="12afael"]my 1987 plexi amp don´t glow on that way. so I think it could be a problem . [/quote]
With the same tubes? If the same tubes behave differently in different amps, then there probably is a problem. Otherwise there isn't.
Some tube (like Philips/Mullard ECC8x) light up like light bulbs at poweron - bot that's normal. Other tubes don't do this at all.
Best regards,
Mikkel C. Simonsen
[quote author="nacho459"]I just noticed that you said you hooked the heaters up to 12VAC, I'm pretty sure that 12AX7's are supposed to be hooked up either to 12VDC or 6VAC.[/quote]
AC is fine. You can use it on either 6V or 12V, depending on how you wire the centre-tapped heater.
Try a tube change if you have any extras. I had a tube that did that all the time. Not enough time to damage anything really. Is it a white glowing flash that slowly diminishes? That's what mine did. That tube lasted forever.
Looks cool. Plus, it scares people away who might want to plug in for a jam. Tell them "the last guy who plugged into my amp got his 59 PAF chrombuckers cooked by that weird heater. :grin:
Check the tube socket.
cj
well I try some tubes a amperex (Holland) was the only one with the problem , the funny think is that I have other amperex and it don´t have that glow . the tube work well . it appear to be normal for that crazy tube :wink: .
I try some RCA, heath (by mullard) , Hewlett packard, telefunken.
I put the circuit description 12v AC then rectified, filtered and reguled.
I use 12 volts DC on 4 and 5 pins .
is exactly what I have.
I will do that!! :grin:
provably the heather material don´t have a soft change on resistance from cold to hot , so a big current flow throught the filament. but it don´t produce problems while the tube is on.
I would like to be able to measure the current on that moment. maybe could be a problem if we have a lot of that tubes.
thanx to all
12afael
[quote author="12afael"]well I try some tubes a amperex (Holland) was the only one with the problem , the funny think is that I have other amperex and it don´t have that glow.[/quote]
Amperex (Holland) is a Philips tube, and they have the "problem"/feature. Other Amperex tubes (made in the US), are most likely Sylvania tubes and they are very different.
Best regards,
Mikkel C. Simonsen
There are some weird country codes on those Phillips/Amperex tubes. Here is a chart with some of them. I have other code info- if you can provide the whole code, I might be able to decipher the date, etc. Look on the base also. Not positive on all of these:
