Help - can't access thread !
clintrubber
The Netherlands
Talking about display errors...
http://www.groupdiy.com/index.php?topic=10006
Yesterday I asked something about my Quadraverb and a few kind people responded - but I can't read what they wrote - the thread won't open :cry: :sad:
I've tried both at home & at work, but same situation... what could be wrong ? All other threads open just fine, but exactly this one doesn't :shock: :roll:
Peter
Hi Peter,
afaik the BBS chokes on not working image links, like this one in your post: http://www.sound-o-mat.com/images/QuadraVerbPlus.JPG.
If you know the post number (which looks like this part in the URL you get by email when watching posts: p=number, like in www.groupdiy.com/forum/viewtopic.php?p=117819#117819
EDIT: 118558 is the number, i think /EDIT
you can try to edit a random post of yours, replacing the p=something with p=numberofthenotworkingposting in the middle of the URL in the browser window, this might get you to the offending posting to remove the image.
;Matthias (in a hacker mood) :twisted:
Peter,
Sounds like your Quadraverb is causing display problems elsewhere too. Haha! Who'd you piss off at A*lesis?
[quote author="EZ81"]Hi Peter,
;Matthias (in a hacker mood) :twisted:[/quote]
Thanks Matthias, that did the trick !
Strange the thread showed fine yesterday evening directly after posting but went bad afterwards. Or something going on behind the scenes when the linking to a file get sensed ?
Bye,
Peter
[quote author="rf"]Peter
I had a Quadraverb freak out once. It turned out that I needed to reset it by holding the Bypass and Program keys during power up. I think you need to save your user presets or you lose 'em.
Here is a cool site that has bunches of reset info...
http://www.rangeraudio.com/presets.htm
Anyway, I hope it is that simple.[/quote]
No, the resetting procedure just refreshes all programmed data, something else. The display-issue seems a hardware fault.
But thanks for that link, convenient to have around !
Bye/thanks,
Peter
[quote author="drpat"]Peter,
Sounds like your Quadraverb is causing display problems elsewhere too. Haha! Who'd you piss off at A*lesis?[/quote]
Indeed a strange display-coincidence. Must admit I did took some pics of my faulty display-unit but was too lazy to upload them - so I linked to a pic on line that went strange.
I don't dare too look - if the display of that unit on that pic has a faulty display now as well then there's really something spooky going on :thumb:
