G9 - Why the 78s12 must be electrically isolated ?
Jazzy_Pidjay
Paris (FRANCE)
Hi everybody!
the question is in the title
the central pin of the 78s12 go to the ground
so why it's important to isolate it electrically ?
i think the central pin of the 78s12 can replace
the Pin1 of the XLR input, to put all the G9 0v to the Chassis ?
why it's not a good idea ? if it's not good ?
:? thanks
Si vous avez plus d'un repérage sur un radiateur, il peut y avoir ennui, puisque le métal sur un pourrait être à un potentiel différent que le métal sur des 7912 par exemple, où le métal me repose à -12 volts croyez. Vous avez que garniture intéressante de transfert d'insulator/heat de toute façon, ainsi pourquoi ne pas ajouter la rondelle d'épaule et ne pas obtenir à certains le sommeil la nuit?
in fact, i have isolated the TIP121 and the TL783C
so only the 78S12 is non isolated and touch the chassis
when i use the 78S12 without the mica, it's really
a lot colder than with the mica, and is the principal reason
of my question ?!
So, there's no real problem if the 78s12 is the only
regulator non isolated ?
thanks for your french answer :thumb:
:green:
Yes, the 78S12 really needs to be isolated from chassis/gnd/0V - even though it's at same 0V potential. If lest un-isolated, you will get a very unpredictable grounding path, and there's almost certainly hum problems connected with this.
When you use mica insulation washers, make sure to use thermally conducting compund as well - otherwise you inhibit the heat transfer seriously.
Jakob E.
I blindly followed a parts-list for the semiconductor components :(
I ordered a 2SD1275AP (2SD1275A-ND) from digikey and not the TIP121.
Specs are the same except its rated for 2A, not 5A.
Should be ok?
