stickjam
Is there any direct measurement technique to determine the actual impedance of an unbalanced output to determine the best resistor value to use to impedance-balance the cold side--without opening and tracing the circuit of the unit under test, that is.
One idea I had was to make a little pigtail cable with a TS plug on a cord going into a little metal box with a TRS jack. A pot with a scale calibrated in ohms would take the place of the cold-to-ground resistor. Connect and adjust for least noise to determine the proper resistor value to hide inside the shell of the eventual permanent plug. How big would this pot need to be? (ie. what is the highest output impedance I'd likely encounter?)
Would that work or am I missing something else?
--Bob
--Bob
