White/pink noise generator?
Svart
Atlanta GA USA
anyone have a cheap and simple schematic for a white noise generator?
analog please, i've found plenty of digital devices and code.
this is pretty much the easiest I have found so far:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/3469
Or a zener with its cathode to ground, either way you are going to need abit of amplification, neither methodes give much for volume. Here is the schematic for the polyfusion noise gen, it also shows how you get some different colors of noise.
According to ARP in the Odyssey service manual zeners give wider bandwidth of noise and more balanced amplitude accross the spectrum. Not sure how true this is but they did reccomend upgradeing all odysseys with this mod.
adam
[quote author="Svart"]anyone have a cheap and simple schematic for a white noise generator?
http://www.maxim-ic.com/appnotes.cfm/appnote_number/3469[/quote]
Just wondering & curious what your application is.
I mean, sometimes a simple playback from a decent soundcard for just a single occasion can prevent having to build (less fun, but more time).
I like the idea of getting a truly random source instead of the deterministic shift register approach. Those always bugged me no matter how long between repetitions. Hickman had an article a while back in Electronics World about how the distribution of some of the SR ones departed from Gaussian despite the belief that they were "perfect".
Having said that, it's tricky. There are companies that make certified noise diodes, and screen for ones without a lot of excess noise.
The good old ways used temperature-limited vacuum diodes. I suppose you could still do that with something like a 6AL5---run the heater current down.
And it would have that "tube sound". :razz:
[quote author="bcarso"]And it would have that "tube sound". :razz:[/quote]
:grin:
Ha, or how about some genuine tape-hiss filter-shaped into a kind of white noise ? :wink:
Paia, lfo+noise:
http://www.synthdiy.com/files/1/20041022/PAIA_2720-5_ControlOsc_NoiseSrc.gif
Pink noise:
Jakob E.
So sue me. I like shift register noise. Like Dewars, it never varies. After it has gone around the loop once, your measurement is done; no leaving it running overnight to average-out the randomness. (I've done that to really nail room noise spectrum.)
Yeah, nobody is perfect. True Gaussian has infinitely small chance of an infinitely tall spike: no SR will ever make an infinite spike. Short ones have low (and of course constant and repeating) peak spike level.
Ignoring good reliable SRs, there are many ways but just two good ways:
* Warm-cathode vacuum tube
* Zener diode
The Zener is far more practical.
The key feature of the Zener, compared to all the other hissers in electronics, is that the noise level is FAR above thermal noise, so we do not have the 1/f rise anywhere near the audio band. Use a BJT or FET or normal VT in a high-gain amp, the noise is white above 1KHz but rises below ~~100Hz. Maybe 500Hz, maybe 10Hz, depending on the device: as mentioned in another thread, 1/f is not as bad as it used to be. Still, the Zener tends not to have 1/f noise at any rate that we have patience to study, or at least will be much better than other devices made on a similar process. And the Zener is noisy which reduces the amount of gain we need to pump it up to meter-level.
It needn't be a real Zener. We don't care what the Zener voltage or dynamic impedance is. Noise does vary somewhat with Zener breakdown, but the standard thing to do is take whatever jellybean BJT is laying around and reverse-bias its Base-Emitter junction. Except for a few old odd types, all Silicon BJT B-E junctions break down at about 7 volts and act as Zeners. The only awkward thing is that you can't get a reliable breakdown with a 9V battery supply: the voltages are too close, the junction may breakdown at 8V while the battery sags to 7V and it stops Zenering long before the battery is exhausted. 15V supplies are good.
The bottom half of PAIA's plan shows the minimum-cost way to do it, if you buy vats of cheap NPN transistors. I do wonder if some of those coupling cap values are big enough. PAIA's synths were pretty funky and flavorful, and weak bass in the noise module would not be considered a flaw.
The plan Jakob posted, though hard to read, is the minimum-cost way now that an opamp is cheaper than a transistor. The output of U1a at the right side of C4 is white, you can omit U1b and all its crap if you don't need pink noise. Don't use the old 1458 chip: TL07x will slew faster and is easier to find today. This can run just as well on +15V, or +/-15V if you watch the cap polarity (C7 C4 will probably need to be reversed for >+/-7V).
As Adrianh says: the Maxim plan is good theory but the amplifier is aimed for 1MHz and up. For 10Hz-100KHz you want bigger coupling caps, and almost certainly a less-excitable amplifier.
Not lawsuit worthy, certainly. I think I just got tired of hearing amplifier testing with an AP System One with a rather short repetition period---it sounded a bit like the little engine that could, and the tests went on for hours. A few more stages and I probably wouldn't have noticed.
I seem to recall low frequency zener noise being rather worse than you describe, but I will have to go back and look.
I just found this thread while searching--and this site which might be intersting:
www.ciphersbyritter.com/NOISE/NOISRC.HTM
Can someone point me to such a part? Thanks!
Samuel
