Samuel Groner
    Zürich, Switzerland
Single rail vs. dual rail in op-amp circuits
« on: October 02, 2005, 01:02:57 PM »
A very nice thing about bipolar supplies is that almost no supply currents flow through ground - this makes ground much cleaner, especially when outputs are class B.
Samuel
Scodiddly
« Reply #1 on: October 02, 2005, 01:32:30 PM »
You're going to need a 15vdc ground reference for a lot of things, I suspect.  Though it's a good idea to set things up so that the coupling caps are biased - definitely worth thinking about.
bcarso
« Reply #2 on: October 02, 2005, 05:01:56 PM »
Most of the stuff I've done for consumer/multimedia products has used single supplies with a half-supply.  Samuel's comment is sensible, although in practice for relatively simple systems it's usually not been a problem.
However, there was one early powered speaker that I used a passive tone control in, and consequently a lot of "make-up" gain.  The board was single-sided and the layout guy had some op amp "-" supply current running through a piece of light trace involving the tone control and gain control ground.  There was an oscillation problem as a result, which was dependent on the setting of the controls---a nasty surprise.
Of course star grounding will remedy the situation.  This can be difficult to enforce when the board size is constrained and especially for single-sided boards.
One thing I do with single-supply designs is try to make the load on the half-supply as light as possible.  To this end, I will use topologies where the op amp inputs are referenced to the half-supply with their non-inverting inputs if possible.  When there are significant currents flowing in filter components these get tied to ground rather than the half-supply, when it doesn't upset d.c. conditions.
Last post October 08, 2005, 01:45:54 AM
by Samuel Groner
Last post January 31, 2010, 08:23:50 AM
by ppa
Last post April 10, 2019, 05:47:42 PM
by squarewave
Last post March 03, 2020, 04:29:40 AM
by abbey road d enfer
