Gus,
I am sure you will get back and comment on your HT supply.
I think 50 Ohm from ground in the output stage should be recalculated as an output impedance of the buffer plus 50 Ohm in series with it, for better impedance balance, and probably another 470 MF (why so high?) should be added from ground in series with calculated R.
Have you tested it yet?
Once I made a mic output as a FET source follwer, with another FET as a CCS, with balanced impedance output. Then the input stage could be made as an amplifier, and then directly couple both stages , using DC for SF bias.
It would be very interesting to compare these two schematics.
