owel
Can anyone recommend a preamp output driver stage schematic composed of discrete transistors (instead of opamp ICs).
single supply voltage... 18V (MUST!)
unbalanced or balanced (pref. balanced)
No output transformer preferably (but may go with transformer-based design too... hopefull not expensive trafo)
I'm "upgrading" an old Altec mixer. The output stage will be used as a summing amplifier (tie together 6 channels via resistors) and/or output driver.
Do you know of any schematic I can "borrow" bits and pieces of the design? Thanks!
