smallbutfine
I'm nearly there with my "zero cost" GSSL...means everything / every part ripped of from electronics waste, ebay industry spares (pcb material, home etched), reused 19" casing from an ole exciter etc....
1)
Now i wonder if i can use MC33078 as a replacement for the NE5532 (specs do look good, and as i understand it, only in use at a symmetrical input NE5532 are better because of their CMRR specs, right? Both BJT, right?)
2)
...and a FET type single opamp as a replacement on the inputs (maybe a Burr Brown i have for spare? opa227 or opa134 or some similar, having quite some right here?) as FET can mostly replace BJT but not the other way round? Right?
Next question:
3)
I can't find 100pF ceramics in my box so i thought of paralleling some 22PF or 33pF, but there's not enough room for that on the pcb...
As i understand it, the resistors limit the gain and these caps limit the bandwidth according to the gain, am i right?
What happens if i lower these to 33pF?
4)
How critical are the capacitor values anyway to prevent oscillation for these opamps (especially the ne5532, but the TL074 as well, even if not in the audiopath)?
5)
In this circuit, is the opamp behind the vca more prone to oscillation than the others?
I wish to get a more intuitive understanding in analog audio design, so i decided to learn from my first diy units this (maybe hard) way....and my green I was a great experience built from used parts - you measure every part, think about its role in the game, think about tolerances and experiment alot without thinking about lost money or wrong orders or things like that. Improvising as a way to more knowledge, not a fast ripoff.
Any comments highly appreciated.
Kind regards
and happy DIY
Martin
1)
2)
Next question:
3)
4)
5)
Kind regards
and happy DIY
Martin
