Ptownkid
Small portable, really portable practice amp
« on: November 01, 2005, 08:54:27 AM »
Looking or info on a solid state amp build, something small like a pig nose.
Any leads?
Rochey
« Reply #1 on: November 01, 2005, 09:19:28 AM »
do a google for "Gainclone"
Expat Audio Home: http://www.expataudio.com
« Reply #2 on: November 01, 2005, 01:19:01 PM »
the ruby over at www.diystompboxes.com is a fun and small little amp that can drive a 4 twelve cab.
good luck.
Ptownkid
« Reply #3 on: November 01, 2005, 04:32:41 PM »
ok, so i checked out the rubt, but there's one thing I don't understand.....
http://www.runoffgroove.com/ruby.html
it shows there being a speaker present, but don't I need to know what watt and resitance the speaker needs to be?
kiira
« Reply #4 on: November 01, 2005, 07:38:49 PM »
foo... it's aguitar amp so it has to have tubes.
http://annex.ax84.com/media/ax84_m276.gif
vibrolax
« Reply #5 on: November 01, 2005, 09:14:28 PM »
Here's one of my guitar mini-amps (all tubes of course), and a bit simpler than the AX84 firefly referenced in the previous post.  Built into a PC power supply box:
Link
Schematic and detailed pics provided.
Jon
NewYorkDave
« Reply #6 on: November 01, 2005, 09:17:14 PM »
...and here's a couple of small guitar amps from yours truly...
Solid-State
Tube
PRR
« Reply #7 on: November 01, 2005, 10:30:57 PM »
Bah. Only wimps and technicians worry about "power rating" and "impedance". Real players just play. If something smokes, it was no darn good to begin with, right?
Speaking as a wimp and technician: I think a LM386 on 9V supply is good for about a half-Watt at most. With a solid 9V supply, maybe a whole Watt of gross distortion, on a 9V battery you won't be able to hold even the half-Watt long enough to melt a small speaker. Yes, if you really shop around, you can find "loudspeakers" that can be melted with 1/10 Watt; if you just grab a kitchen radio from the second-hand thrift-shop, its speaker will take everything the LM386 can dish out.
Impedance? Well, the LM386 will distort more at medium level with 4Ω than with 16Ω, but at full-blast it is all about the same.
Oh: a half or whole Watt may seem like it would be lame next to your 80W big-amp, but you can make a heck of a racket with a part-Watt and a good speaker.
Oh: put this little amp into a twin-twelve cabinet and it will make a very gutsy racket yet not at such volume that you wake people two streets over. That does not fit your definition of "portable", I suppose, but do try it with a big speaker. A fairly large speaker, like a screaming-Six, in a large but lightweight (corrugated cardboard, or 3mm plywood) box will make the most of a minimal amplifier.
> it's a guitar amp so it has to have tubes.
Agree, but: tubes are such power-pigs that battery or ultra-compact construction just isn't happening. When location is more important than tone, you can make a nice noise with an FET/386 amp and a 9V battery, and play anywhere.
kungfugeek
« Reply #8 on: November 01, 2005, 11:59:58 PM »
Anyone know of any circuits similar to this?  http://zvexamps.com/ampsound.html  I think it sounds fantastic.  I am not looking to clone the Z, but achive a similar sound, with similar flexibility.  Would be used strickly for recording, so 1/2 watt is ideal.
PRR
« Reply #9 on: November 02, 2005, 01:58:54 AM »
Many amps can, when played "through a 1970 Orange 4X12 cabinet with 4 original Celestion greenbacks."
What strange tubes. They must have got a Good Deal on a case of those. Offhand, I doubt you want a "faithful clone" because the tubes are probably not the "sound", it is the way they are used, and those tubes are just strange. Probably missile spares.
Use the kitchen-radio tubes. 60FX5 is a killer one-watt, you could run 75-90V on the plate for part-watt use. 50C5 were used by the millions, and a 50C5+12AX7 can be fed 62V plate and heater and make a half-watt. 50EH5, 50FK5, 50HK6 are similar (minor differences in ratings, but mostly I bet the radio-maker wanted a monopoly on replacements...). 50L6GT is the classic Octal of the tribe, runs a lot like 50C5 except can take more voltage, and can be stoked up to nearly 4 Watts output. I think all these (except 60FX5) are 0.15A heaters so you can stick a 12AX7, 12AT7, 12AU7, or 12SN7 12SL7 or even 12SJ7 in front for gain. Tinker the tone-stack, gain structure, R-C coupling networks for best guitar action. After 50 years, the Fender front-end is still the foolproof way to start.
« Reply #10 on: November 02, 2005, 02:56:51 PM »
Quote from: "Ptownkid"
ive built a few of the ruby's and i can tell you that they sound great!  if you want something a little more powerful, the ruby mkII is a 1 watt version using two 386's ....
one time i plugged one into a genz benz 2 12 cabinet...and it was plenty loud enough, and there is something about the way it overdrives that sounds really gutsy and nice.
the parts are easy to get a hold of....you can get them at ratshack if you'd like....
also - someone inquired about a smaller tube amp like zvex's....  there is the "sopht" amp that's pretty small and sounds really good...cant remember the maker's name, but i want to say it was "johan."  full diy information on his site....google it.
see ya-
casey
« Reply #11 on: November 02, 2005, 02:58:47 PM »
here is an example of a ruby someone built:
kiira
« Reply #12 on: November 02, 2005, 03:59:35 PM »
Quote from: "Lo-Fi"
gah that is soooo cute I wanna build one but I can't stand to listen to anything through less than a 12" cabinet... and I like a 4x12 or stack best. There is just something about that "whump" you get with a closed back 4x12 or stack. Ok I'm a dinasour from the 80s for liking my V4 and jcm800.
Kiira
CJ
« Reply #13 on: November 02, 2005, 04:24:37 PM »
Lucky homeowners.
 :cool:
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
bcarso
« Reply #14 on: November 02, 2005, 06:09:32 PM »
Quote from: "kiira"
Quote from: "Lo-Fi"
Kiira
But Kiira, wouldn't that be a cool thing to carry into a posh retaurant as if it were a handbag?
« Reply #15 on: November 03, 2005, 09:28:57 AM »
Quote from: "kiira"
Quote from: "Lo-Fi"
Kiira
you could easily put a switch jack on it so that you could plug a cabinet into it.  or you could just build it as a head and put it into any cab you'd like.
Ptownkid
« Reply #16 on: November 03, 2005, 10:34:52 PM »
on the schemo it list the pots as being1k-b and 10k-b, what does that mean?
« Reply #17 on: November 03, 2005, 11:00:59 PM »
Linear taper.
Ptownkid
« Reply #18 on: November 11, 2005, 12:29:22 PM »
Ok, so i built two of these guys, and all I get out of them is distortion, or a lot of distortion, there's no cleanish tone at all.
Also, when you pluck a note, it hardly sustains at all and then quickly crackles off into nothingness in the blink of an ye, it's like it's got a gate.
Mbira
« Reply #19 on: November 11, 2005, 12:57:30 PM »
Clean tone is a result of lots of headroom (extra power).  You probably won't get much clean headroom from one of those.
Joel Laviolette
Rattletree   |  https://www.rattletree.com
The Rattletree School of Marimba | https://www.learnmarimba.com
Last post December 26, 2005, 07:25:19 PM
by enthalpystudios
Last post January 08, 2009, 12:30:20 AM
by gswan
Last post January 06, 2009, 03:07:44 AM
by Whoops
Last post July 06, 2013, 01:57:25 PM
by ChrisRoberts
