G
Guest
Guest
I have got this cable from Canford for sending DC from an external PSU to a EQ
http://www.canford.co.uk/commerce/productdetails.aspx?productid=34-941
THis is rated at 100V/3A - foil screened - has 4 insulated wires and a drain wire
Sorry for the simple question...
I am using 4 pin XLRs for this...
If I send 18v,0v,-18v down the cable how do I wire up the 4 pin XLR?
Do I use the drain wire for the 0V or just use the normal insulated wires.
