Rack cases: tip of the day
Viitalahde
Kuhmoinen, Finland
Some Hammond cases will fit the 19" rack standard perfectly.
For example, the box 1441-32 from 1441 series (http://www.hammondmfg.com/dwg20.htm) measures 432mm wide, 254mm deep and 76mm high. This means that it's pretty much the size of a 2u case.
At least I would be able to pick up a case like this for 23 ?. Bolt a blank panel in front and you have a sturdy box.
:guinness:
And they're available in aluminium also: http://www.hammondmfg.com/dwg21.htm
Best regards,
Mikkel C. Simonsen
[quote author="Viitalahde"]Some Hammond cases will fit the 19" rack standard perfectly.
At least I would be able to pick up a case like this for 23 €. Bolt a blank panel in front and you have a sturdy box.
:guinness:[/quote]
yup. Then can you buy 3mm aluminum front panels or even 6mm ones and have a really nice 2u case. I've done this once or twice and I am building the Kiiratronics Uberbox into one like this... 6mm panel.
Kiira
Speak to the direct distributors - I have done this myself
They will tell you who has how many in stock.
I have done this with OTHER Hammond cases - in that they told me they retuinrded all of them to the USA and wouldn't reimport them.
They were really helpful.
UK and Europe Distributor
Hammond Electronics Limited
1 Onslow Close
Kingsland Business Park, Basingstoke
Hampshire RG24 8QL
United Kingdom
Tel: 01256 812812
Fax: 01256 332249
e-mail [email protected]
This is a good idea.
Can someone post pictures of their frontpanel attached to the hammond chassis? I'm curious...
Where do you get the front panels?
I actually researched this as well, but figured out that after buying the chassis, the top and the front panel, it's cheaper to go with a Par-Metal box.
Peace,
Al.
This is how I built my LA-2A, but it was an LMB 17"x4"x5" chassis on a regular 1/8" thick 3 space aluminum relay rack panel.
[quote author="tk@halmi"]SHIT COMES WITH NO TOP![/quote]
Did you buy one and forgot to order the top, or did you order the top and they didn't ship it? If you did order the top: how much did the whole thing cost you?
Peace,
Al.
I ordered it and did not realize that the top is sold separately. I was going to put Front Panel Express plates on the face, but without the top it is not economical unless you wanted to make a custom lid for it. The Par-Metal case is a better deal so I am sticking with that next time.
[quote author="tk@halmi"]without the top it is not economical unless you wanted to make a custom lid for it. The Par-Metal case is a better deal[/quote]
(*clears throat*)
[quote author="alk509"]I actually researched this as well, but figured out that after buying the chassis, the top and the front panel, it's cheaper to go with a Par-Metal box.[/quote]
It sucks. The only reason they sell the tops separately is to fool the innocent into thinking they're getting a better deal than they really are. I mean, who the fuck would need a box with no top?! How can you even call that an enclosure?!?!
Peace,
Al.
