lang_dave
Active member
Hello everyone - I'm looking for some help with a Yamaha M916 mixer. I'm not an expert but am interested and would like to learn. I can solder, use a multimeter, find parts on a schematic / find those parts on the circuit board, and have a beginner's level understanding of what those parts do and how the signal flows.
This board works well and is in good shape, but I'd like to see if I can make it sound a bit more like my Speck Xtramix line mixer - that is, less noise, more bass, and clearer, more 'present' & 'defined' sound (if any of that makes any sense).
This board relies on unique op amps (Toshiba TA7322P) that don't have anything like a pin compatible replacement, so I'm probably not going to be rechipping any time soon.
So, my questions are:
1) The power supply is inside the mixer's case. There is a metal shield on top of it. Should I bother moving the power supply outside of the case into a seperate enclosure? I was thinking that might help reduce the noise.
2) Any suggestions for parts to replace in the power supply to improve its performance? I have a schematic posted here. From my reading I'm guessing the electrolytic caps should be replaced. Suggestions for cap values / other part replacements would be appreciated.
Thanks for any help / suggestions / ideas. There's a PDF of the complete service manual with schematics posted here if you're interested - note that it's nearly 20MB, though.
thanks again,
dave
thanks again,
dave
