Another G9 ! Pics too...
Zee1usa
Seattle,WA USA
Thanks to Jacob, Greg Stein (parts list) and you all !
-OEP Trafo in and out.
- JJ / Tesla Tubes
- Amveco 35VA Torroids
- Lorlin switches & Alpha Pots
- Arcotronics capacitors (yellow)
- Cornell Dublier (blue) (560u/450v) kinda big but i think should be ok.
- Mallory Poly (black squares)
- Front Panel done at front panel express $60.00
- Radio shack heatsink in pic did not work, heatsink is now attached to chassis which I was expecting I might have to do. All is well now (amen)
- LM783 (thanks maxwall)
- PCB (thanks Gustav)
http://img.photobucket.com/albums/v359/zee1usa/G9/G91.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G92.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G93.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G94.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G96.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G97.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G98.jpg
http://img.photobucket.com/albums/v359/zee1usa/G9/G95.jpg
My 1/4 inch jacks should be here monday from mouser as they were out of stock when i ordered them a couple weeks ago.
No smoke on power up!
Listening tests soon..
Z :wink: :guinness:
Very nice one :thumb: :thumb: :thumb:
The Lorlin/Alpha type mains switch might be a little weak in this application. They are not rated for power. (But to be honest, I used them too, with two contacts paralleled :oops: )
:guinness:
alo zee
congratulations.
the only thing i`d have done another way,it`s the dissipator in the tl783,because it gets very hot.i screwed mine to the bottom of the box.
my g9 it`s the go to pre to room drum sound,because it is damn clean,altough i used lundalhs.
congrats once again.
best regards
pedro
[quote author="jensenmann"]Very nice one :thumb: :thumb: :thumb:
:guinness:[/quote]
Thank You, I will condsider changing this out with an appropriate switch.
[quote author="caps"]Nice! Make sure you let us know what you think of the sound.[/quote]
Thanks , Will do.
[quote author="louder"]alo zee
congratulations.
best regards
pedro[/quote]
Thank you,The Radio Shack heatsink will not do which is what I expected from all the reading in G9 thread, and is now attacheched to the chassis.
I bet the Luhndals are very nice!
[quote author="peter purpose"]Very nice job z...... :thumb: :thumb:[/quote]
Thank You Peter!
[quote author="jetboatguy"]Very nice, you're inspiring me to make one... one of these days. :cool:[/quote]
I hope to see yours soon!
Z
Please don't do this.
Regulators can easily selfoscillate or give you a lot of noise . Put bypass caps soldered excactly to regulators legs if you can.
Nice job, instead :thumb:
cheers
fotis
Thanks for the comments Guys, I appreciate it !
[quote author="FotisGR"]Please don't do this.
cheers
fotis[/quote]
Thanks for making me aware of this !
I have been working on my G9 this weekend and have it working 100%.
I had a few issues which I wanted to mention as it may help someone building this for the first time.
The issues I ran into were:
1) The INST. Jack I had it wired wrong. At first I had no signal and the wires were very sensitive like a guitar pickup (noise/hum) because it was wired incorrectly. Then I wired it up and it was working , but the INST in was buzzing even though I could hear my guitar. Now it is working perfectly.
QUOTE: "The signal from the input transformer goes to the switching part of the input jack - so it is switched out whenever a jack is inserted. If no jack is inserted, it reaches the gain stages... Jacob"
Note: see my diagram: INST Jack Wiring
2) I did not have the ground (at the 5 wire connection) connected from the main control pcb to the switching pcb. The switches did not do much until this was corrected. I was trying to do the "G9 oscillation problems - solution" MOD and forgot to connect this ground lead.
3) The Heatsink was not large enough, but now I have a very large heatsink. FotisGR suggested having the regulator mounted with long wires may cause some self oscillation and create noise. I have a very very small (almost unnoticable) hum which may due to this?
4) I have have a black painted Par metal case and I made sure the entire box (each panel) is reading zero ohms in reference to the chassis ground.
Z
PS ...The G9 sounds wonderful ! ! !
[/img]
Zee1usa,
Can you tell me IF the $60 front panel from FPE included them drilling the holes for you or not ?? Thanks.
[quote author="caps"]Zee1usa,
Can you tell me IF the $60 front panel from FPE included them drilling the holes for you or not ?? Thanks.[/quote]
Yes, the drilling of the holes only adds about $5.00 to the total.
It would be about $55.00 without holes drilled.
Another thing, make sure to be aware of wether you are sending in your own aluminum panel or if FPE will be supplying it. There is a check box for it if you did'nt already know.
- Arcotronics capacitors (yellow) they are 5uf each.
