kevinc
Cutting sheet aluminum
« on: July 18, 2004, 09:47:26 AM »
If you can find a friend with a table saw, a normal carbide wood cutting blade will do the job if the feed rate is slow.  I now use a blade especially made for non-ferrous metals, but before I had this I used a wood cutting carbide blade.  Eye and ear protection is a must here!
Kevin Carter
K&K Audio
www.kandkaudio.com
« Reply #1 on: July 18, 2004, 01:43:56 PM »
A really nice tip I got from an ex-Army Engineer pal: Keep a candle handy, and rub the wax across the cutting blade or tip of the drill, it makes for a much smoother passage through the panel.
If you're nervy about swarf getting into motors or pcbs when cutting steel, keep a magnet handy. I once left some swarf across the terminals of a 1.5Kva / 88,000uf reservoir per-rail power-amp supply, it made a hell of a flash and the burning swarf flew across the room!
Justin
Prepare yourself. You are about to become the voice of Interplanetary Parliament.
SSLtech
« Reply #2 on: July 19, 2004, 12:01:11 PM »
BTW... The word 'Swarf' makes a tech-friend of mine from Nashville grin... apparently it's a UK-specific word, he always laughs when I use it!
keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
CJ
« Reply #3 on: July 19, 2004, 09:59:33 PM »
Masking tape over the cut zone will help to control flying metal.
 a little bit.
Oh, and a OT tip=place a piece of round thin cardboard at the top of a drill bit to keep the strands of drilled Al from getting too long.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Last post June 15, 2006, 03:21:19 AM
by guavatone
Last post August 25, 2006, 12:54:52 PM
by CJ
Last post October 02, 2007, 08:07:11 AM
by keefaz
Last post September 06, 2008, 03:35:23 PM
by Gold
