Svart
ok maybe not the greatest but maybe the best for the opamp/capacitor upgrade guys. I have chosen the most likely candidates for usage in the opamp world and those caps that I find are either the most transparent and the most warm out of all AFFORDABLE caps... the Nichicon HE and PW series.
each channel has around 5000uf of rail capacitance total to ensure that the opamps are not starved causing strange artifacts. any gain/bandwidth setting resistors/caps are left as is.
The OPA404 are quad FET input and fairly neutral in color. I could not source the OPA4134 or OPA4604 for this test without going to great lengths to get them or going out of my way to build adaptors for them. Testing with those will come later. only one stage of an OPA404 will be in the signal chain because there will be NO EQ performed on the tracks.
here's a breakdown of the channels to be compared:
5532, tl084 and tl082. nichicon HZ caps. stock channel
Vs.
opa2604, opa404, no caps
opa2604, opa404, nichicon HE
opa2604, opa404, nichicon PW
opa2134, opa404, no caps
opa2134, opa404, nichicon HE
opa2134, opa404, nichicon PW
mc33078, mc33079, no caps (expect DC offset issues due to BJT inputs though these are very low offset)
mc33078, mc33079, nichicon HE
mc33078, mc33079, nichicon PW
opa627, opa404, no caps
opa627, opa404, nichicon HE
opa627, opa404, nichicon PW
(these needed special adaptors)
and finally:
AD825, opa404, no caps
AD825, opa404, Nichicon HE
AD825, opa404, Nichicon PW
(these need special adaptors)
I am finalizing the parts roundup and buildup of adaptors for the special opamps.
I will be testing using Mics with Marik's circuit design with linkwitz modded Panasonic wm61 capsules.. roughly equal to an Earthwork$ mic. For preamp i will be using an SSL9k pre. Tracking will be via an Echo MIA at 44.1/16 straight to disk.
The test subject will be the toughest of all objects to accurately capture and reproduce.. A Sabian HH 13 splash.
I have most of what I need and have some of the initial tests done. I have done no analytical tests whatsoever and will let the tracks speak for themselves.
This has cost a pretty small fortune but should benefit a lot of folks here.
Only thing I ask is.. who has space to keep the tracks online?
Let me know what you think or if I am wasting my time here.
:thumb:
Vs.
and finally:
:thumb:
