kdawg
I decided to try and hack apart an Alpha dual linear 500 ohm pot to see if I could transform it into a 3-deck pot. It sure seems like it would work:
The original dual pot:
Back open on the dual pot:
Taking spring side of another Alpha pot and epoxy it to the dual pot:
What the final thing will look like:
Now my question is - can I use a 5k audio taper pot as the 3rd deck to make this work as a ~500 ohm T attenuator or do I need a different taper (Z taper)?
-kdawg
-kdawg
