Testing: -> Old Unmarked Power Transformers <-
northsiderap
Michigan
Lately I've been checking out power supply design, and I have an assortment of old unmarked power supply transformers to check out.
I have been measuring DC resistance and trying to draw out a schematic of which wires I think are supposed to go where... Then I have a beefy 50k I attempt to load the secondary with.
Sofar I have messed up a few transformers in a big puff of smoke and usually a nice 60hz buzzing sound... I'm starting to get shell shocked from all the fireworks.
:shock:
Anyone have any better way to test old unmarked power xformers? Tomorrow I'm going to use a 1 VAC generator if no-one has any better ideas...
I seem to remember that most power transformers follow a common color code.
The 1 volt generator is always a good plan and my prefered way around unknown transformers. The following is used in conjunction with the ratios as discovered with the 1 volt measurements.
This is from memory, so take with a large grain of salt.
Primary: Black
Filliment : Green
HT : Red
Bias : Blue or Yellow
Any center taps will contain the basic color, ie HT CT : red with yellow stripe.
or Red with White stripe etc.
I'm sure CJ will be here soon to clean this up. :?
Hope this helped.
Peace - Out, Irv
Forgot to add that I measure unterminated voltages, ie No Load.
I just terminate all wires on a screw type terminal strip and poke away with the meter and 1 volt gen. after I take my best shot at the primary, I'll power it up and measure volts again. This way if I guess wrong usually no magic smoke is released in the process.
You could also power up the transformer primary with a light bulb in series for current limiting and indication.
Peace - Out, Irv
[quote author="KingKai"]I seem to remember that most power transformers follow a common color code.
[/quote]
Not old russian ones. :wink:
For a common low voltage transformer primari dc resistance is bigger than secondaries.Also thicker wire means usually low voltage big amperage secondaries.
"Not old Russian Ones"
D'oh I hate it when my North-American myopic view gets in the way! :oops:
Well at least the light bulb should lessen the occurance of magic smoke emanating from the test subject. :razz:
Peace - Out, Irv
I'm in a similar situation. I have two old U.S. made power transformers that are potted and contain no information. It's hard to tell the colors of leads but it appears to be
2 Black
2 Green
1 Green/White
2 Red
1 Red/White
2 Orange
2 Blue
Does anyone have a rough idea of what all of these might be used for? I'm going to try the 1v generator idea assuming the black is the primary.
Ryan
The generator should be applied to a winding that has sufficient inductance. Applying it to a low-volt winding is bound to make measurements difficult.
That's why it's important to rough up the job by measuring the DCR and assessing the wire gauge.
That reminds me I have a couple big old transformers to throw away on junk day this month. I bought them back in the 70s as surplus. If I haven't used them yet, unlikely to ever.
[update, yesterday I threw out both transformers and an old broken statue of a china man (missing his head). This morning the transformers are gone but the broken china man remains... apparently scavengers collected the transformers for scrap value.  [/update]
