I have been wondering about this for awhile now, looking at the curves of rectifier tubes it is apparent that choke input offer more stable operation, voltage stays fairly constant despite current changes, but more voltage drop then a capacitor input. Where capacitor input filters sag with increases in current draw but have less voltage drop. So it seems that Capacitor input filters are fine for single ended amps where current draw is fairly constant and choke input for the other classes, assuming sag is not desired. But everynow and then I see a single ended schematic that uses choke input. Does choke input have other advantages, does it clean things up better or is this done for other reasons, to get some voltage drop on purpose or plain ol not knowing better. I am just about to start building a small practice amp not sure if I should go for a choke input or throw a cap between the choke and rectifier and use those extra volts since this is an SE amp and sag is not an issue.
adam
adam
