Metal film VS carbon comp poll
Metal film VS carbon comp resistors which sounds better?
  • Metal Fim
    Votes: 0 0.0%
  • Carbon Comp
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
Sounds better for what?
I would always use the metal films. But that's because of the stablility and noise - I don't want to select resistors and check the values once a year...
Best regards,
Mikkel C. Simonsen
I don't know about sound of resistors. I think some believe carbon comp are a large part of vintage toob stuff (ie guitar amps etc). I've not investigated, looked for, nor experienced a difference (except higher noise). I don't think a resistor should have a "sound". If it is a good part with low noise and a respectable ppm tempco it should not matter.
I've been using metal film for a couple of years now and see no need to look further. Each time I need a different value, I just buy a pack of 200 from mouser and add the value to my stash. After a couple of years at this, I'm certainly biased toward metal film! :thumb:
Peace - Out
Irv
I have 4 la2a's here that are built with carbon comps...
I have a few la2a's here that are built with metal film.
bench wise the metal film measure much better...
I think you would be hard pressed to hear a difference between them other than increased noise on the carbon comps.
the trannys play a bigger role than the resistors.
so I have to vote for metal film
I'd like to say I voted for carbon...
because I really don't have a clue & wanted to see the results of the poll :green:
Todd
