Viitalahde
This is the oddest grounding (?) problem I have ever encountered.
I built a GSSL for a friend few months back, he runs it through the patchbay, typically used in unbalanced inserts.
There is always a constant buzz present, and it's not even 50hz buzz, I think the fundamental is 150hz. We have now tried pretty much everything:
1) Pin 1 connected at one end only (both input and output have been tried)
2) Pin 2 connected at both ends
3) An 1:1 isolation transformer tested at both input and output, grounds referenced @ the GSSL end
4) My own, loaned unit at the same physical place in the rack = the problem doesn't go away. Both units measure and work fine at my place! My version is also very different from the stock version by the I/O and PSU.
5) Shutting down ALL the gear at the same rack - no help (and none of them do the buzzing, and they come through the same cabling and patchbay.).
6) Lifting ground from the power cord (don't kill me! I did it just to see if the problem is at this area - situation legal now )
7) Using other cabling (including running the unit to the console individually, balanced) - no help
This is really odd. Nothing helps and it's clearly not the units fault since my own version does the same thing too. None of the other equipment does the same thing, including an inner SSL limiter I built inside the consoles mix buss, the Neve-ish preamp and a stereo 1176 (the same I posted pictures of a while back) so it can't be my construction techniques either.
It's almost like it just doesn't like being in the studio. Everything from galvanic isolation to shield/pin 1 manipulations have been done. Oh, the racks are made of wood too, so the gear doesn't get a chassis-chassic contact through it either.
Is a big hammer the fix?
