Mbira
I'm working on this Fender Deluxe Reverb. Customer had it all f&%ked up. Blown power transformer. OT running 16 ohm marshall speaker. Everything disconnected inside, etc. Anyway, I have replaced the PT and rewired OT (it's a hammond) to 8 ohms fender speaker. All voltages look good. When speaker is hooked up, it gives off this sickening high pitch squealing along with a low pitch hum (even with all pots turned to zero). Feeding a signal thru lets the signal pass, but all that noise is there. The strange thing is that when I hook the speaker jack up to a 8 ohm power resistor, I can't see any noise on the scope. When the speaker is plugged in, noise is there. I switched speakers, and it's the same.
What the hell?
What the hell?
