G
Guest
Guest
I know its a stupid question - but I seemed to have missed the lecture on "Finding out the bleeding obvious"
A pot like this...
How big is the hole in the front panel?
Is it for the 6.35mm shaft?
Or the square, half circle bush(?) with the thread?
And if it's not the half circle bush - how do stop your knob twisting the thing around - I know you can tightnen up with a nut and washer - but is that enough?
Commons sense tells me it must be just the shaft that goes through - otherwise the knob is not going to sit true on the face of the front panel
But I just want to check
A pot like this...
