SSL US / North America parts list
nacho459
Pasadena CA
Here's the parts I used. People keep asking, so I figured I'd post it. It's a little different from other people?s posts. Almost everything is from Mouser or Digi-key.
Mouser Parts:
653-A165L-AYA-24D-2 Lighted Switches (x2) $13.44 each
161-0707-1 IEC power plug (x1) $0.74
44FH033 Fuse holder (x1) $1.11
10WA365 2x6pos rotary switch (x2) $2.57 each
10WA367 4x3pos rotary switch (x1) $2.57
313-1210-50K 50K Linear Pot (x2) $1.99 each
575-113308 8pin IC socket (x7) $0.32 each
575-113314 14pin IC socket (x1) $0.62
575-113316 16pin IC socket (x2) $0.71
(you need 3 straight 8pin sockets for your 2150?s. these 16pin sockets get cut in half)
512-1N4148 Diodes (x6) $0.50 each
These are all the resistors, you don?t need 10 of each, but Mouser has a minimum order of 10 resistors. I am going to be building several of these so I don?t mind having extras. Other suppliers don?t have minimums, so if you want to find them somewhere else, here goes the values.
2x 1.2M OHM 1/4W
1x 1.8M OHM 1/4W
2x 10 OHM 1/2W
6x 100 OHM 1/4W
3x 100K OHM 1/4W
10x 10K OHM 1/4W
2x 120 OHM 1/4W
5x 15K OHM 1/4W
1x 180K OHM 1/4W
7x 1K OHM 1/4W
3x 1M OHM 1/4W
1x 2.7K OHM 1/4W
3x 20K OHM 1/4W
1x 221K OHM 1/4W
8x 22K OHM 1/4W
3x 270K OHM 1/4W
1x 27K OHM 1/4W
1x 2K OHM 1/4W
1x 3.3M OHM 1/4W
1x 3.9M OHM 1/4W
1x 33K OHM 1/4W
3x 39K OHM 1/4W
2x 47 OHM 1/4W
1x 470K OHM 1/4W
6x 470K OHM 1/4W
6x 47K OHM 1/4W
1x 510K OHM 1/4W
1x 560K OHM 1/4W
1x 56K OHM 1/4W
2x 620K OHM 1/4W
2x 68 OHM 1/4W
1x 68K OHM 1/4W
1x 750K OHM 1/4W
1x 8.2K OHM 1/4W
1x 820R OHM 1/4W
1x 82K OHM 1/4W
1x 91K OHM 1/4W
At Mouser simply enter the 271- then the resistor value IE:
271-47 = 47ohm resistor
271-2.7k = 2.7k ohm resistor
When you get to the Megaohm level enter 291- then the resistor value IE:
291-3.3M = 3.3Meg ohm resistor
one last thing, the 10ohm resistor should be a 1/2 watt,
so you will need part 273-10
Digi-Key
P5586-ND 1000mF 63v radial electrolytic cap (x2)
P5540-ND 100mF 25v radial electrolytic cap (x4)
P11213-ND 22mF 25v radial electrolytic cap (x14)
399-1359-ND 6.8mF 35v cap (x1)
399-1352-ND 0.47mF 35v cap (x5)
BC1030CT-ND 10pF 50v ceramic cap (x10)
BC1034CT-ND 22pF 50v ceramic cap (x10)
BC1036CT-ND 33pF 50v ceramic cap (x10)
BC1042CT-ND 100pF 50v ceramic cap (x10)
EF1104-ND 0.1mF 100v metal poly cap (x25)
296-7040-5-ND IC op amp (x2)
296-7043-5-ND IC op amp (x4)
296-1775-5-ND JFET IC op amp (x1)
296-1777-5-ND JFET IC op amp (x1)
W04GDI-ND rectifier bridge 400v 1.5A WOG (x1)
296-13999-5-ND voltage regulator 15v 1.5A (x1)
LM7915CT-ND voltage neg 15v 1.5A (x1)
LM78L12ACZ-ND voltage regulator 12v 100mA (x1)
NJM79L12A-ND 12v negative regulator (x1)
TE62063-ND Power transformer 110-15v 1.664A (x1)
D4AA54-ND 50k ohm trim pot (x2)
Other Junk
THAT 2150?s http://www.profusionplc.com/
PCB?s http://www.theaudionet.ltd.uk/kitchen/
Yokogawa 286-1 FS=1mA meter www.metersales.com
Instrument Meter Specialist 1756 Victory Blvd Glendale CA
Sifam knobs http://www.selcoproducts.com/CFM/Knobs/Conventional-knobs.cfm
Selco Anaheim CA
If you look around the 10 minimum is only on the Xicons. You can get the KOA Speers 1% Metal Films in any quantity. I went with them wherever I could since they're a LOT cheaper (3 cents each), and the only worse spec seemed to be that they're twice as sensitive to temperature changes (100 ppm vs. 50 ppm). Mouser doesn't have as many values for them though. Somebody correct me please if there's some glaring error in using them.
