Batuu
ssl clone make-up problem - Solved
« on: December 30, 2005, 07:37:04 AM »
he guys,
yesterday iI finished my first ssl clone. my problem is, that the make-up gain effects on the compressen mode and the bypass ... so I can't  fix the make-up so that I can compare compressen and bypass sensible. Is it possible to fix it, tht to make-up don't effect on bypass?
Bye
Olle
radiance
« Reply #1 on: December 30, 2005, 07:46:36 AM »
On the control pcb there is a jumper wire (next to the 750K resistor). When in place, the make up gain is always active. The describtion on Jakob's site explains how to wire the bypass switch using a lorlin rotary....
If you have any more questions about the ssl clone use the SSL Help Thread
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
emtee
« Reply #2 on: December 30, 2005, 07:49:15 AM »
You need to wire the bypass switch as detailed here -
http://www.gyraf.dk/gy_pd/ssl/ssl.pdf
It sounds like you've missed out the make-up switching to the lower right of the release control.
emtee
« Reply #3 on: December 30, 2005, 07:50:59 AM »
Echo   Echo   Echo   Echo
 :grin:
Batuu
« Reply #4 on: December 30, 2005, 09:36:09 AM »
thanks for your answers ...
the problem with the jumper is, when it is connectet make-up gain effects both and when it's not connectet it effects neighter of compressor and bypass ...
emtee
« Reply #5 on: December 30, 2005, 09:52:59 AM »
That's why you need to connect switch it, if you see what I mean. Instead of the jumper, you use half your bypass switch. Have another look at the diagram in the link I posted before.
Batuu
« Reply #6 on: December 30, 2005, 11:23:59 AM »
Thank you for support.
Now everything works ...
emtee
« Reply #7 on: December 30, 2005, 11:24:48 AM »
Good feeling eh?  :thumb:
radiance
« Reply #8 on: December 30, 2005, 02:36:02 PM »
Good :thumb:  :thumb:
Now edit this post and put the word "solved" behind the topic tittle.... :grin:
Last post November 27, 2004, 09:11:26 PM
by cayocosta
Last post October 17, 2007, 10:03:39 PM
by Emperor Tomato Ketchup
Last post September 18, 2005, 04:27:45 AM
by Seedysea
Last post February 17, 2013, 04:06:21 PM
by Bowie
