NTP 179-400 limiter card schemo + documentation - Here!
> ..requires acroreader 6 or above..
My PDF writer says that this will open in "All versions of Acrobat". However it is much bigger than the original....
NTP Datasheet PDF, 4.6 Megs
strangeandbouncy said:
Dear All,
    goto
          http://homepage.mac.com/strangeandbouncy
      enjoy!
        ANdyP
ANdyP,
Could you upload these info again please?
Opacheco.
hello all - sorry to revive an old thread again..
Is there anyone that still has a copy of this?
https://groupdiy.com/index.php?topic=46971.msg790506#msg790506
Im racking a pair of these now.
I put this in another thread but here is a link to 10P BCD switches
http://www.ebay.com/itm/281287437093?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
So I have these on the bench now.
External PS with a power one putting +24.8VDC and 0 correctly.
The cards fire up, green LED light and signal passes through both channels.
Interesting though: there is a huge LF roll-off.
While directly connected to calibrated
Stereo AD and DA the signal is down -30--40 dB and with pink noise,
huge slope to nil LF and is on both channels...def not correct....
The connector diagram is a bit vague:
is out put pins:
18,19,20  or 19,20,21?
Also, is 18 (19) output hi, 19 (20) output lo and 20 (21) shld?
DEFINITELY 19, 20 and 21, as mine were on 18, 19, and 20.
I switched the pins and voila - full signal
though still curious about XLR pin 2 & 3 orientation vs these pins at connector...
