Hey all you LA2A gurus out there, I have a few questions for ya.
I had posted an inquiry last month searching for ADL 1000 schematics. None to be found so far.
Let me state that I am not a tech person and could not DIY anything BUT I have 2 ADLs and I want to modify one to get it closer to an LA2A. From what I?ve read from you guys, it?s a good starting place as a unit if not DIY from scratch. The ADLs sound fine but I'm looking for something else.
I?ve read that all the various pieces used on the ADL (i/o trans, tubes, T4B) are interchangeable with the original pieces and I have managed to find the NOS UTCs and NOS 60s RCA tubes and NOS T4B.
I?ve read all sorts of threads about the ADLs (bad grounding etc) and the LA2As and now I need someone (you guys) to tell me what else I need to look into to make the change.
I have a friend that will do the mod or I should say do what mods I ask for so I want to be well versed when asking. Is just replacing the new for old enough? What about caps and other things like the power supply?
Enough ??? for now?.
Your responses are truly appreciated.
AQ.
AQ.
