I think 35104 is just a BBC spec 35102, but don't quote me on that. It could be hearsay. I glanced at a 35102 schematic once and it looked like the IC was only switched in for extra gain, above 50 or 60dB or something. But again, I could be wrong. I'll double check this next time I remember. Also, while we're on the subject, allow me to debunk the myth that an Audix 35102 is the same as a Neve (3)3114. NO WAY! The overall approach and end goal are the same (these two companies were competing for the same jobs, afterall), but the Audix circuit, both as a whole and considering each stage individually, is a different beast. The iron is different too... and there's no high current output stage to drive an output transformer. Which begs the question, why not add the 283AM stage with gapped transformer while you're at it? :wink:
Anyway, back to the original question. I think you'd be better off replacing the 5534 with another of the input amp stages Audix already uses in there. There's still going to be changes w/regards to feedback networks and gain structure (yes, you're going to have to hack at the sensitivity switch, no doubt), but I'd bet it'll be less than needed if you put a Neve 283AV amp stage instead. Makes a lot more sense to me.
