imo
I shall fall gracefully and ask for information, some of which may seem pretty inane, so pardon my ignorance.
Having finished a Hamptone tube mic-pre with little trouble i have inched up to the Tangible-Technologies 1176 kit. I bought an enclosure based off of their prototype( 1 rack space aluminum) and I am waiting for my Digikey/Mouser parts to come in. I have a few questions that i was hoping to clarify before i jump into the build next week.
1. I have the Cinemag input transformer (model CMLI 10/600BPC) it has no mounting bushings or anything. What is the best way to mount this? I could pull it tight against the enclosure with a tension tie, but so far that is the only solution i have come up with
2. The output transformer is pretty tight in this enclosure. Should it be isolated from the enclosure walls? I can't find any way to mount it other than against the back panel, which would leave both the top and bottom snug against the aluminum. The wires, of course, would be isolated, just wondering if this would cause problems?
I appreciate any information. I have been reading everything i can get my hands on and trying to digest as much info as possible, but the curve is a bit intimidating at first.
thanks
thanks
