clintrubber
As read here:
http://www.cathedralstone.net/Pages/Neve1073.htm
:roll:
As long as the additional preamp ('third section') is not relevant - so for gains less than say 50dB -, I wasn't aware of any differences.
What could they be meaning w.r.t. that smaller bottom ?
I'll further compare the circuits, but thought that these beasts would be sounding identical for gains under 50dB and properly micpre-modified 1272's.
Peter
This unit consists of two Neve 1073 mic pre-amps as sold by Neve in the 70's (mic pre only-no EQ) with the same low end and 80DB of gain. A 1073 module with EQ is referred to as a "1073", and the pre-amp only section of a 1073 is referred to as a 1290. So the actual name of these modules is "1290", but they are the actual pre-amp in the 1073 module.
These aren't to be confused with the more commonmodified 1272 pre-amps with a smaller bottom end and only 45db of gain.
:roll:
Peter
