analag
NYD's passive EQ, ghetto edition
« Reply #140 on: March 01, 2006, 09:32:47 AM »
Had to revive this thread. I just finished winding an EQP1A inductor with an added 70mH on top of the 150mH for a 2k frequency select (220mH total). I used a P-3622-77 pot core, from CWS Bytemark. A few minutes of experimental winding showed me  AL=6665 not 7680 as they claim on the website. I calculated all my turns based off of this value and swept all the frequencies with the appropriate caps in place and only the 16k sweep was a few Hz off(capacitor related), everything else was dead on.   Total resistance is 2.3 ohms. It took me all of five minutes to do it by hand, with some #26 wire I had lying around.
analag
Audio engineering suffers from misinformation, disinformation, and downright lying more than most fields of endeavour.
Viitalahde
« Reply #141 on: March 01, 2006, 09:57:01 AM »
Damn, I still need to wind my own some day.. Well done!  :thumb:
NewYorkDave
« Reply #142 on: March 01, 2006, 10:07:19 AM »
Good info, Rowan. I was considering those cores, myself.
alk509
« Reply #143 on: March 01, 2006, 10:14:08 AM »
Good job, Analag! :thumb:
You gotta keep in mind that those pot cores are spec'd with a 20% tolerance. So, 7680*.8=6144. I'm going to be doing some winding as soon as I get a counter and a hand-drill I got off eBay (thanks for the inspiration, NYD! :thumb:). My plan is to overwind using Al=6144, and then remove turns until I hit the sweet spot.
My EQ will have 10 bands - 1 band per octave, or 32Hz (shelf), 64Hz, 125Hz, 250Hz, 500Hz, 1KHz, 2KHz, 4KHz, 8KHz and 16Khz (shelf) - with selectable shelf or peaking response on the 64Hz, 125Hz, 4KHz and 8KHz bands. :cool:
I'll try to document the build for the group's perusal.
Peace,
Al.
Lest laziness get the best of you!
analag
« Reply #144 on: March 01, 2006, 10:22:12 AM »
Quote from: "NewYorkDave"
It a damn good looking core too. Comes with a white plastic nut, bolt, washer and bobbin.
When winding, take all your taps from the same slot, including the begining and end.
Viitalahde
« Reply #145 on: March 02, 2006, 06:43:49 AM »
BTW, I just added some series resistance to the highest band, thought it was too sharp. I ended up with a 200ohm resistor, way better now. I reckon it took about 3dB away from the maximum boost. Didn't even bother to measure.  :razz:
NewYorkDave
« Reply #146 on: March 05, 2006, 04:04:32 PM »
I drove right by the Fair-Rite factory the other day. If I'd planned ahead and left in some extra time, I could have stopped in and asked for some samples  :?
analag
« Reply #147 on: March 05, 2006, 06:56:36 PM »
Hey Dave, it's better if you roll your own to the required specification of what you're building.
NewYorkDave
« Reply #148 on: March 05, 2006, 07:20:56 PM »
Fair-Rite sells cores, not complete inductors.
radiance
« Reply #149 on: March 06, 2006, 07:39:00 AM »
Dave: Looking at your scematic I was wondering if it's possible to make a very simple version of your EQ, one with only 1 frequencie selector switch with 6 positions (2 X low, 2 X mid and 2 X high) and 1 cut/boost rotary switch.
I'm in the proces of "thinking of building" a 10 X  stereo channel active summing box and a very simple passive EQ would be a nice addition.
It will be all stereo EQ's so I'll need some hefty rotarie switches.
(this "thinking of building" proces will be taking some more years  :grin: )
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
Viitalahde
« Reply #150 on: March 06, 2006, 07:47:40 AM »
Then you'll feel pissed off when you need both low and high.  :wink: I'd suggest that you make instead a 2-band version with fixed, wide frequencies. Same amount on knobs. Low shelf at, say, 100hz and a w i d e 12-14k peak?
radiance
« Reply #151 on: March 06, 2006, 07:58:58 AM »
Yeah, that would also be an option.On the other hand, this EQ will only be for  mild coloring, not for hefty EQ tasks.
One thing that I want to get rid of is that 2 pole 12 position rotary (I don't think it's possible though) ...when building a stereo version it will be 4 pole 12 position and quite costly  :sad:
Viitalahde
« Reply #152 on: March 06, 2006, 08:01:06 AM »
Well, if you're not going for heavy EQ'ing, you could go with less maximum boost/cut..? That would make the switch requirements simpler.
But the boost/cut switch only needs to be a two-decker for stereo material.
radiance
« Reply #153 on: March 06, 2006, 08:19:44 AM »
Quote from: "Viitalahde"
Maybe I don't have the latest schematic, but mine sais that for the high bands (5k, 10k and 15k) I need a 2 pole 12 pos rotary for boost/cut and a 2 pole 3 pos for frequencie selection...(for a mono version that is)
radiance
« Reply #154 on: March 06, 2006, 03:45:37 PM »
Viitalahde: looking at your version of NYD's EQ I don't see any 4 deck rotaries. Your's is also a stereo version right?
alexidoia
« Reply #155 on: March 06, 2006, 03:49:16 PM »
Quote from: "donnysparks"
i wish i had saved more of your scematics rather than bookmarking the threads
I just thought the same eating my fingernails... :)
I understand NYD althought this a difficult decision to make. Having said that  he said he would give it out to regular members of the forum, so no need to be sad.  :)
NYD: have you thought about the GPL licenses ? Maybe that would be a good think to keep your work public.
I am very new here, but already love this forum. I took on a electronic course and bought some books. I always wanted to do DIY audio but did not think I would manage anything until I met you guys.
Thanks.
Viitalahde
« Reply #156 on: March 06, 2006, 04:06:19 PM »
Quote from: "radiance"
Yes. You only need one deck per channel.
radiance
« Reply #157 on: March 06, 2006, 04:09:19 PM »
GREAT :thumb:
NewYorkDave
« Reply #158 on: March 07, 2006, 01:48:45 PM »
The two-deck switch on the high band is because I wanted peaking boost and shelving cut. If peaking boost AND cut is acceptable, you only need a single deck.
Viitalahde
« Reply #159 on: March 07, 2006, 01:54:56 PM »
Ah, now I got it - Radiance was referring to that pretty new schematic.  :thumb:
Last post December 02, 2006, 11:16:43 AM
by raysolinski
Last post January 30, 2007, 10:49:26 AM
by Jed
Last post July 31, 2007, 06:53:15 PM
by kato
Last post March 17, 2010, 04:36:17 AM
by [silent:arts]
