ESR and recapping
« on: January 27, 2006, 10:55:19 PM »
A While back I bought Dick Smith's  ESR meter.  I tend to find that somethimes, more often than not the old caps don't really have poor ESR coampared to the new one( i tend to spurge for the best).
Case in point, Klark Tektik D780 Reverb(1980's) caps in the power supply were lower ESR .2 compared to Panasonic-NHG .36   -
This is one scenario but other units I knew needed to be recapped because of humm/noise, showed that caps wern't too leaky.  I changed caps anyway and the unit sounded f#@ing great and quiet.
Any ideas?
bad ESR meter?
old caps had fine ESR but no capacitance anymore?
ESR
« Reply #1 on: January 28, 2006, 11:54:30 AM »
I have a capacitor wizard ESR meter  and although I think its works fine I have found the same : older caps don't necessarily exibit bad ESR or to a point of determining that the cap is beyond use. In fact , I have found few bad caps with this meter so I'm thinking ESR is not a very common problem with caps in general if I go by what my meter is telling me.
I do think that dried out caps are more of an issue , but no meter or measuring device that I know of will tell you if you have a dried cap.
you simply replace it based on age, and caps have  better and tighter
specifications with each newer generation of product lines and offerings.
I have also found that recapping cheaply made gear does not change its tone or sound quality. Adversely, Quality gear will bring out the sound /tone nuances of different types of caps.
curiousaudioparts at  gmail  dot  com
https://sites.google.com/site/diypartsstore/
Gus
ESR and recapping
« Reply #2 on: January 28, 2006, 12:27:50 PM »
Caps can lose cap value and still have good ESR
Caps can have good cap value and the ESR can be bad.
I think it has to do with the chemisty and the construction of the electro cap.
Last post October 25, 2004, 05:04:36 PM
by Steve Jones
Last post April 05, 2007, 08:28:48 PM
by Milkmansound
Last post November 11, 2008, 08:31:31 AM
by mrphotodude
Last post October 28, 2009, 05:59:47 AM
by FotisGR
